scary tires
RE: scary tires
ORIGINAL: Viper_GTS-R
when one of your wheels come off the ground with the throttle wide open is it supposed to swell like that? is it the rpms?
MA
RE: scary tires
I'm a landscaper and live in massachusetts it's covered with snow so I'm home ALL the time now but i get to spend more time with my 1 year old so thats fun.
KS
RE: scary tires
ORIGINAL: tegwin
What would happen if you block up all the holes on the wheel rims. The tires are much harder, has anyone tried it??
WV
RE: scary tires
My tires don't balloon if I'm not on the throttle. Make sure you're not using the throttle or brakes when you hit the ground. It's rough on your diffs.
RE: scary tires
The balloning thing is normal...... too much will hurt the glue tho, its all in how much throttle you give it in a particular situation, as for drilling extra holes I find putting the hole in the rim not to be as good as putting a hole in the tire.... thats if you need to do it at all because its not going to stop it balloning ! When you put the hole in the rim the dirt/water/whatever gets spun/forced into the tire&foam, putting the hole in the tire makes the crud get flung out of the tire&foam. When your tires get dirt&water in the them then get unbalanced and that really really sucks, I`ve had tires come out 30-50 grams heavier than the others and they wobble like crazy and make the truck not fly level in the air !!
TM
TM
RE: scary tires
You have no reason to doubt me. You might be interested to know that i am a graphic desighner using CAD and i am adequatley qualified to make silly animations like that one.
MA
RE: scary tires
Yes thats great you know cad but I have seen that specific one on other websites so yes i can doubt that you made that particular one. ohh and no I am not interested that you are a graphic designer.
Banned
NY
RE: scary tires
ORIGINAL: DaSHiKi
Come on... this is a savage forum, not a reality tv show chatroom!!!
Who cares, he might have made it for others, or he may not be telling the truth, but, who really cares...
Yan
Banned
NY
Banned
NY
RE: scary tires
It is also way smaller than any other I have seen, about two kb's, most are around 7 kb. He is probably telling the truth... Lets ralk about the Savage!!!!!!!!!!!
Yan
Yan
RE: scary tires
I dont realy care if you dont believe me. This is the kinda arguement i used to have with people when i was about 6.
Lets talk about something more grown up like savages.
