HPI Monster Truck Forum Talk about HPI monster trucks here. The infamous Savage 21, SS, .25 or any other HPI MT. You can optionally discuss HPI in our general MT discussion forum if you prefer.
spur gear bad already??
Old 03-20-2004, 06:20 PM
vizaracer
vizaracer's Avatar
Default spur gear bad already??
i ust put a brand new spur gear in my truck and look at it already. help me.
Old 03-20-2004, 06:22 PM
lax195
lax195's Avatar
Default RE: spur gear bad already??
i cant really see what is wrong.... is the gear melted?
Old 03-20-2004, 06:26 PM
vizaracer
vizaracer's Avatar
yea, its melted. do you know what caused it??
Old 03-20-2004, 06:41 PM
lax195
lax195's Avatar
you might have put it on too tight, or maybe your engine is too powerful. might wanna look into a steel spur gear.
Old 03-20-2004, 06:44 PM
vizaracer
vizaracer's Avatar
i put it on alittle tighter than before because it was sliping way to much.
Old 03-22-2004, 05:08 AM
matster
matster's Avatar
Tighten it all the way down. If you go to www.savage-central.com and read up on what people are doing with thier bigger engines, you will see that guys using Wasp's and Picco's are doing this. With the Sirio I think it is a V.good idea.
Old 03-22-2004, 12:34 PM
FiReD-uP
FiReD-uP's Avatar
the picture you posted? that dosnt look like mine, mine the teeth are all chewed up and melted. did my engine move?
Old 04-06-2004, 07:39 PM
bulldogbud
man i put like a doz spur gears on my car i am tired of it.
Old 04-06-2004, 07:43 PM
bulldogbud
man i put like a doz spur gears on my car i am tired of it!!!!!!!!!!
Old 04-06-2004, 07:44 PM
doctorgoodwrench
doctorgoodwrench's Avatar
i run the picco 26 which makes pretty strong power, running the stock 52 or 49 tooth gear and tighten them all the way down and then off 1/4 turn, and have had no problems. also make sure you are using a friction pad on the spur. one more thing..... your slipper spring may be weak, consider replacing it with that big engineif you have any amount of run time on it. backing it off a 1/4 turn is important though for the harder landings on power to keep some of the stress off you transmission and related components.
Old 04-06-2004, 07:48 PM
bulldogbud
i tried that but the gear keeps on melting
Old 04-06-2004, 07:56 PM
bulldogbud
do u know where i can get i think a 44 t steel spur gear?
Old 04-06-2004, 08:35 PM
vizaracer
vizaracer's Avatar
nope. i have a 48 tooth spur gear
Old 04-06-2004, 08:52 PM
skyneverdie
vizaracer, you posted it a while back agao that you got a STEEL spur gear from RR,
Is it the Steel spur gear that u melt??????
Old 04-06-2004, 08:55 PM
vizaracer
vizaracer's Avatar
nope. it was the plastic. this is an old post. i have the RR set now and it works perfectly fine. no more melting!
this post goes back to 3/20
Old 04-06-2004, 08:58 PM
skyneverdie
i will receive my steel spur gear tomorrow
did you tight all the way down?
is there a pad behind the spur gear like the one in plastic?
Old 04-06-2004, 09:06 PM
vizaracer
vizaracer's Avatar
no it doesnt come with one. you have to get one. i tightened mine all the way down.
Old 04-06-2004, 10:42 PM
mike1288
mike1288's Avatar
My Kong's kept Eating stock Gears. Replaced with RR Steel, Much better, Gear looks like it wobbles alittle but it seems to drive fine with it.
Old 04-06-2004, 10:47 PM
vizaracer
vizaracer's Avatar
yea, they work great. my sirio ate mine.[:@]
