truck won't run!!
truck won't run!!
Hi, i just got a brand new Savage 25, and when i try and start it, it cranks up but then cuts out after just a second, why is this? Please help out I wanna get the engine broke in. Also my remote is weird, when i turn the wheel left it goes right, when i turn it right it goes left and when i hit the gas it applies the brakes and when i hit the brakes it works the throttle, why is this!? I've switched the buttons on the remote and it doesn't make it do it the right way, it doesn't have any effect at all with the switches that should reverse these things or make them normal. please help, is my remote messed up? And I've tried adjusting the idle speed and it still cuts out!! please help.
Thanks[&o]
Thanks[&o]
RE: truck won't run!!
umm try to put a new glow plug in........and i have no idea about the radio. the stock one isnt all that great so if you have the money i would get a new one.
ON, CANADA
Dude, look on the right side of the transmitter just behind the steering wheel. If you are running the stock servo's the should all be reversed. As for your engine conking out after a second or so. Check the glo plug, but more than likely the low needle is too lean.
don't mess with the factory carb settings until you've broken in the engine.
here're a couple of things you need to take note before starting it.
check that when your throttle is at idle, the carb should be opened at around 2mm (check the engine manual).
make sure your engine's not flooded (you'll know it's flooded when it's impossible to pull the cord)
make sure that there're no kinks or pinch on your fuel and compression lines,
make sure there're no air bubbles in the fuel line,
make sure that your glow plug's healthy (unscrew it plug it into the glow plug starter,
the entire filament should glow bright orange) and
make sure that the glow starter's fully charged. do not use more than 1 cell (1.2v) or you'll fry the
glow plug filament.
if your engine starts, leave the glow starter on for about 5 seconds before removing it.
hope this helps...
glow plug filament.
hope this helps...
