no start fuel
KS
no start fuel
both my igniter and RS are fully charged and when i try to start it i get nothin
so i took the tube from the exhaust to the tank and i blew fuel into the cyllinder
and the stupid thing starts just fine!!?? anyone had this problem or have any solutions?
RE: no start fuel
The engine needs to be 'primed'. The RS will do the job, but, you need to put your finger over the exhaust stinger while you turn the RS, until you can see fuel going into the carb.
Personally I prefer the blowing tecnique. it is a lot quicker and you don't risk busting the One-way.
you could, if you wanted to buy a primer pump like this,
http://store.savagess.com/product_in...d70b79cf8c527f
Have fun.
Have fun.
RE: no start fuel
Check the exhaust for air leaks. The finger over the stinger trick has the same effect as blowing down the pipe.
What pipe are you running?
