Tire recommendation
RE: Tire recommendation
ORIGINAL: savagemanrc
What type of tires do yall recommend? I heard the stock tires aren't too great.
What surfaces?? Grass? Tarmac? loose dirt? compacted clay?
Just asking , 'What tyre should I buy?' doesn't really help unless we have some idea of what use you have for them.
The stock tyres are actually pretty good with the right foams.
I want somthing that will perform good on all surfaces you mentioned that will last a LOOOONG time and are wider than the stock tires (handling)
WA
Sorry Matster. I spaced. It was late at night at the post. I would need them mostly for yard bashing. I looked into the big joe's but they are pretty expensive. One thing I was wondering if the Tmaxx tires would work better.
