wont move
wont move
i was racing friday night and made it through both heats. when we started the main
i ran about 4 laps and the truck would'nt move. i can pick the truck up off the ground hit the gas and the tires will spin it'll even change into 2nd gear. but when i put it on the ground it still will not move. with the engine running i can hit the throttle the clutchbell and spur both turn. i pulled the engine out saturday and checked the clutch shoes look fine flywheel is tight, pulled off the spur gear everything seems ok there to.
anyone know of anything else to check i'm lost????
RE: wont move
Seems like your slipper clutch is too loose...
So, it won't run on the ground, but if you lift it off the ground it will run and shift. Either the slipper clutch or the centrifigal clutch in the clutch bell. I can't think of it being anything else. When it's on the ground, do you see the driveshafts rotating? Maybe your front and rear diffs are stripped OR the transmission has a problem internally. It shouldn't be too hard to find- that's a big problem!
RE: wont move
ORIGINAL: speedy_29
seems to me that if the diffs were stripped or there was a problem with the ranny the wheels would'nt spin at all?
RE: wont move
Are your tyres/wheels ok?? The wheels may have stripped out (hex's) or the tyres may have come unglued. They would still turn with no load. What about the set screws in the drive cups???
RE: wont move
OK, since we are talking about Savages that won't move, how about this one. I just took my truck out of hibernation recently and I've been out driving it and noticed an odd problem. I'll be driving around just fine and then I'll make a semi-fast run and slam on the brakes and it'll sound like the transmission on a full size truck when it slips out of gear. It'll sit there and rev like a raving maniac for a little bit and then it'll "shift" into gear and take off. Sometimes the only way I can get it to take off is by giving it a bit of a push backward. HELP!!!!!!!!
Thanks guys (and sorry for tagging on to this thread)
WV
RE: wont move
ORIGINAL: RC Monster Man
Not to change the subject, but Asking the Savage Dias, Do you like the hot bodies tires & wheels?
RE: wont move
Ummm, I'm having a hard time figuring out where the one way in the tranny is (looking at the exploded views and assembly instructions from HPI's website). Any hints on where I'd find that sucker?
TN
RE: wont move
no clue. i have never taken my oneway out before but that could be the problem. by just guessing, i would say it is located near the two speed gears. possibly even in them.
WV
RE: wont move
Aluminum diff cups? Did the stock cups not wear out fast enough or something? Admitedly I haven't seen any cups other than the stock ones but I'd hate to think I could install some that are softer than the stock cups. My diff cups have a groove larger than the ones the pins were meant to go into.
