tunin savage
tunin savage
ok i have a savage and i bought it like 2-3 days ago and i wanna know i used it for bout 2.5 tanks and would it get faster if i use it more or should i jus tune it if i do how do i tune it ?
RE: tunin savage
You need to run it in!!!!!!!!!!!!!! 2 tanks run at idle (sitting on a box or something with the wheels off the ground) then 3-4 tanks running in a figure 8 or round in circles. That should run the engine in sufficiantly.
When you have finnished the break in procedure, THEN and ONLY THEN should you tune the engine.
READ THE MANUAL.
READ THE MANUAL.
TN
RE: tunin savage
i'd say the same thing as matster. he is right. the engine will also gain alot of power around the 8th tank and will fully gain its max power when you are done the first gallon.
RE: tunin savage
ORIGINAL: matster
READ THE MANUAL.
READ THE MANUAL.
TN
RE: tunin savage
i would atleast idle the first tank. i idled the first 2 tanks. pretty much you are getting everything set like the bushings and stuff in the engine and not getting the temps up to break in the engine.
