Wheelie Bar Help Please
NJ
I am having Wheelie bars made by a friend at his metal shop and I left my measurements home . Could someone please measure their standard wheelie bar lenght and width . As well could you measure the distance from the mounting screws over the hump to the other screws. To better explain I want to mount the plate to all four screws instead of just the last two . I know I will have to cut around the hump . Please give what ever measurements and or pictures that have worked for people . I put the Picco 26 in my truck . It runs fine on road but I cant keep it on all fours or twos in the dirt . I was also told that to long a wheelie bar will twist the frame . Is that true .
RE: Wheelie Bar Help Please
ya know that integy, gpm, and new era make wheelie bars. i had the integy one and it worked but all i can say is TAKE YOUR WHEELIE BAR OFF when you are jumping .
i had the one from integy. it mounted below the chassis and it screwed in on the back of the skid plate where those 2 countersunk screws are.
no i did not 'brake' it but i bent it so much that it bent INTO the back of my skidplate and my skidplate had a little indent in it. hehe.
