savage stuck in reverse
NJ
My savage is stuck in reverse. i went to adjust the break end point on my MX3 radio and now it is running in reverse . i can not find the manual to fix this problem or the airtronic website with the manual . Walk me through getiing it to go forward and the proper way to set the end points .
My second question is that my Picco 26 is finally broken in and i leaned it out .When I get to half a tank it shuts off . What can this be ? I made sure the fill cap is closed .Am I to lean ? there are no holes in the line .
first and foremost get me out of reverse.
RE: savage stuck in reverse
the savage fuel tank self leans as it gets half my which is causign your engine to over heat richern it up 1/8 turn
if you want to fix this problem the totally you will have to do the duel tank mod.
hope this helps
hope this helps
