info about wasp .28
info about wasp .28
aight i found these infos on the net so i just thought u might wanna see it
ABC piston/sleeve
Turbo design race ported crank
Knife-edge double bushing connecting rod
High performance 8mm aluminum slide carburetor
Skirted / double oil groove piston design
3 transfer, 1 exhaust race spec porting configuration
2-piece replaceable button style Turbo head
6 bolt / 12 fin head configuration
Sleeve locating pin for precise port alignment
Turbo glow plug included
Specifications
Exhaust: Rear
Carburetor: 2-Needle Slide
Crank: Standard SG
Horsepower: 2.85
RPM (max): 42,800
Bore: 18.5mm
ORI80500 Wasp .28 w/pull-start $279.99
ORI80501 Wasp .28 $269.99
ABC piston/sleeve
Specifications
Exhaust: Rear
Crank: Standard SG
Horsepower: 2.85
RPM (max): 42,800
Bore: 18.5mm
