IS IT ME OR EVERYONE SUCKS AT THIS
ON, CANADA
RE: IS IT ME OR EVERYONE SUCKS AT THIS
It has to be you. I can thread an antenna wire thru the tube in less than 7 seconds. 1-blow a bit of spit into the tube. 2-run the lead thru your fingers a couple of times to smooth out the bends that are in it from being coiled up. 3-run some spit up and down the lead. 4-insert lead into tube and gently push it thru. Simple & easy.
NJ
I usually spray wd into the tube. Then I vaseline the wire and coat it with baby powder. Then I dunk the tube into a pan of 10w-30 and using some silicone and a fishing hook, loop the end around a stationary object like a wall or tree trunk. Now position the tube over the antenna wire and hammer it on with a ball peen hammer. BAM! Done. See...wasn't that easy? [sm=spinnyeyes.gif][sm=thumbdown.gif]
I could only get the wire through half way, so i cut the tube and put it through the other half and that put tape to connect both tubes together.
