IS IT ME OR EVERYONE SUCKS AT THIS
yeah probably the hardest part do change in your truck
PUTTIN THE WIRE THROUGH THE ANTENNA!!!!
idk y i took it out but it wont go in i tried it for like an hour and after that i did it but still any1 experiencing that and gettin frustrated?
<watch your language! - i8tweety>
PA
RE: IS IT ME OR EVERYONE SUCKS AT THIS
dude i HATE doing that. it'll go half way then just crinkles when you try to push it more than a thousandth of an inch at a time.
ow man its not that hard i have a 30 inch antanna tube for my planes antanna and i got it all in in 5 mins its easy
Bader
KUWAIT
Bader
KUWAIT
My Feedback: (10)
CA
It took me forever before I learned about this. Spray some windex down the antenna tube then it'll just slide in about 99% of the way then you just have to take about a week and a half to get the last cm in. lol It takes me forever.
My Feedback: (8)
AL
man, you can just spit in the antenna tube, or rub your finger somewhere on your truck where oil has collected and then run your oily fingers up the antenna wire. in my experience, once you crinkle the wire, just pull the 90 degree made with your fingers. this will make the wire a little curly, but it takes the kinks out.
its the easiest thing. Use baby powder or flower on the wire then stick it thru. Or you can just spray WD40 like other ppl said.
when i got my savage it took me the hole Freaking day, i was so happy that i got the savage and i couldnt run it that day[:@]i was so [:'(] that i was going crazy.
i think that a person that can put the stock wire throught the antenna in less than 5 minutes its a pro
trust me its easy i didnt use any thing guys said on top and the planes reciver have a long antanna and i want to make it the same color of the plane so i got it in with a 30inch antanna its really easy and it only take me 3 mins
Bader
KUWAIT
Bader
KUWAIT
KS
ORIGINAL: lax195
uhhhh, it usually takes me about 8 seconds.....[sm=RAINFRO.gif]
When I first got my car I thought they gave me the wrong tube with it because it was so hard. I kept putting it in as far as it would go and then take it out flip the tube and put it in that end. I just kept doing that until eventually the wire came out the other end. Now its a breeze.
