whats the difference
WA
i am looking at geting an xtm 247 motor and i am wondering will that pop my front up on command.
and what is the difference between these.
http://www.hobbypeople.net/gallery/146027.asp this one is suposed to have a SG shaft
http://www.hobbypeople.net/gallery/146028.asp this one is suposed to have a Reg shaft
http://www.hobbypeople.net/gallery/146030.asp this one is 6 port, big head, SG ,PS
what dose all that mean[&:] and why is the top two the same price?
thank you
thank you
VA
RE: whats the difference
That's the one you want. The one with the grey body makes a bit less power, and it's a bit cheaper.....
VA
The weaker version again, with the gray body, is cheaper... You want the Pro version, it has the shaft you need for the Savage.
The output shaft is (just the crankshaft) what your clutch/flywheel will mate up to....
WA
ok thanx guys and dose it have more power than the stock one?
and is it easyer to tune and will it keep that tune for a long time?
