Help -- What Clutch Bell to ise w/ a 49t Spur Gear?
NJ
Apologies in advance if this particular issue has been discussed.
I replaced my original 52-tooth spur gear with a 49-tooth version. The instructions indicate that the stock clutch housing does not mesh well with the 49-tooth replacement.
Can any of you share your expertise as to what tooth-size clutch bell housing fits/meshes best with the 49-tooth Spur Gear?
thx
thx
