good hop ups
My Feedback: (12)
WI
good hop ups
i got a savage ss and i was wondering what kind of hop ups that would be good for it? i am not doing any real racing just backyard racing and bashing
PA
RE: good hop ups
[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXJLH6&P=0]HPI 4 Bevel Gear Diff Conversion Set Savage *u need 2 of these*[/link],[link=http://store.savagess.com/product_info.php?products_id=713&osCsid=3fa76dbaeaa23d48f9b879c183a54ee7]Aluminum Diff Case *u need 2 of these*[/link],[link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXUZ89&P=0]High-Torque Servo[/link],[link=http://www.extremercmotorsports.com/item--HPI-Savage-MIP-CVD-Center-Axles-pair-HPI-80847--HPIMIPCENTERCVDSHAFTS]center cvds[/link],[link=http://www.extremercmotorsports.com/item--HPI-Savage-MIP-CVD-Side-Axles-pair-HPI-80844--HPIMIPSIDECVDSHAFTS]axel cvds *u need 2 of these*[/link] that is some stuff, and thats what im planning to get for my savage. hope that helps!
IL
RE: good hop ups
One important mod I did was change the way the stock HPI throttle / brake linkage works. The stock linkage requires you to overcome a 'C' spring. As your batteries in your receiver get low, the servo's can't overcome that spring efficiently and you loose throttle and brake response. Additinally, you can eliminate the spring on the carb if you get a fail-safe (this is a good idea anyway). Right after doing this, my truck started pulling wheelies due to the snappier throttle. Here's a pic [link]http://www.rcuniverse.com/forum/upfiles/108069/Hf10051.jpg[/link]
Another good investment is a hump pack and charger. This will eliminate the need to ever get into that receiver box again.
