newby with problem
newby with problem
i am the new proud owner of a savage 25.................hi all!!!!!!!!!!!!!!!!!!
only took 2 days to see it shelved, as i have cracked the fuel tank. i believe this is a common problem and have several remedies and preventions on this forum.
the only confusing thing to me is that i believe the savage 25 has a stock 160cc tank (bigger than the 21) and is primer-less....... The question i have is should i replace with stock or is there a better product, as i have to buy one whichever..........does the 25 tank suffer with the half lean problem like the 21? i didn't have mine going long enough to know
the last problem i have is i am from and still live in the uk, near manchester........are there any stockists here?
AZ,
RE: newby with problem
well i believe the stock s-25 tank will be fine. new era models might have an upgrade fuel tank. you might want to get a fuel tank guard so it doesn't happen again if you were bashing.
NJ
yesget both the new era models tank, and the guard. its def worth it. The tank is a little bit smaller, 125cc i believe but you really dont notice the difference. it also fixes the half lean problem. http://www.neweramodels.com/cgi-bin/...x&part_id=1553 and http://www.neweramodels.com/cgi-bin/...x&part_id=1704 worth every penny
many thanks guys.............. by the way , HAPPY NEW YEAR TO ALL! ................it is 3am here of 2005....all the best
