If you're just bashing around...
If your're going to be bashing around full time with a savage, is it better to run 10k or 30k in the spyder diffs?
what are pros and cons of each?
thanks.
thanks.
PA
RE: If you're just bashing around...
well thicker oil = less diff slip. so the heaver the oil, the worse ur turning but u get better traction. so it all depends on what u want
i run 100k oil in my diffs, but then i run my truck in very rough off road conditions with lots of hills so traction is very important to me
how much worse will steering get?
im thinking in using 10k but i don't want to lose alot of steering.
thanks.
thanks.
neil.jb
How is your steering with 100k, it must be really f*&^ed up.
if your steering is no that bad ill go with 60k
thanks.
thanks.
I run 10k in front and 7k in back and it AMAZING. I dont spin my tires off the line and it is just the right amount of "locking" in the diff to make acceleration as good as it can get.
