help with NIMH power pack
ON, CANADA
i purchased a venom racing 1100 NIMH power pack for my savage, no where on the package tells
me how long the initial charge has to be?? it does not tell me how long normal charges has to be???
can someone plz help me.
thanks
thanks
VA
RE: help with NIMH power pack
Charge for 9-10 hrs. If it isn't all the way dead you can go a little shorter. Li batteries last a bit longer (their life that is, not a single charge) if they are never run ALL THE WAY DEAD.
ON, CANADA
thank you all for the help.
so 9 hours for initial charge. and to charge when the battery dies agian 9 hours.
i thought initail charge is allways more than the normal charge.
if you want a good CHEAP charge that is foolproof pick up the reciever pack charger& power supply from a revo.I got mine with a battery pack brand new out of the box for $17 dollars on ebay!!! just plug it in & when the light stops flashing your done in about an hour or so total.
What is a decent charger, that monitors and stops a charge when it is done, that can also charge different types of packs. like a hump pack, and the one for the RotoStart, and gloplug. Not real expensive also, like around 60-70 or less...
