HPI Monster Truck Forum Talk about HPI monster trucks here. The infamous Savage 21, SS, .25 or any other HPI MT. You can optionally discuss HPI in our general MT discussion forum if you prefer.
Ofna throttle/brake linkage mod.
Reply
Old 01-07-2005, 07:01 PM
otee453
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Ofna throttle/brake linkage mod.
I am modifying my linkage set to the ofna linkage set up. I have run into a minor clearance issue at the servo. There seems to me to be more than one fix to this and I was wondering how others have installed their set up. Some side and above pix would be great. My problem lies at the servo horn and clearance at the frame. Thanks
otee453 is offline
Old 01-07-2005, 10:49 PM
Fumunda_Cheese
Fumunda_Cheese's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Ofna throttle/brake linkage mod.
here's a link http://www.savage-central.com/ftopic2179.html
i can't seem to find my camera to upload some pics
Fumunda_Cheese is offline
Old 01-07-2005, 11:23 PM
Rex2342
Rex2342's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Heres how I set mine up
Rex2342 is offline
Old 01-17-2005, 11:01 PM
AdamBlevins
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
very impressive setup. Would you mind sharing where you bought the upgrade kit?
Nice truck by the way!
AdamBlevins is offline
Old 01-18-2005, 08:12 PM
otee453
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I built mine very similiar but I had to do some minor work in addition to what rex2342 has done. First you must buy two of the OFNA throttle linkage kits. You must also buy an additional piece of the hardest/stiffest linkage rod you can get. You also must do your own z bends so you need a tool to do that with. To really get your brakes to work well you need some additional springs. I also put a 20mm aluminum servo arm on the linkage. I enjoyed building my linkage but it was not just a simple kit you throw on the truck, it requires alot of customizing if you want to set it up like rex2345 has done and have it work.
otee453 is offline
Old 01-18-2005, 09:51 PM
Polar_Bus
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Heres my setup (scroll down the page to see my post)
http://www.rcuniverse.com/forum/Sava...2527828/tm.htm
Polar_Bus is offline
Old 01-19-2005, 12:56 AM
802's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just did this mod. Will get batteries for camera tomorrow. I could not find long link bars so I bent piano weir and It seams to be holding up fine. I will let you all know after I bash some more.
Instead of buying two kits you can probably get away withe an Ofna slider kit, and piano weir. http://www2.towerhobbies.com/cgi-bin...?&I=LXBL84&P=7 (I like orange) Mine is on order so that I can set it up like rex 2342. But for now I did mine like the set up on the Savage central link. http://www.savage-central.com/ftopic2179.html
The tool that I used to do my Z bends is something everyone should have in there tool box, nedel nose pliers. Chanel locks, or even vise grips would work to.
Have fun!
I love this sight!
I almost forgot. You will need some brass wheel collars, I got 1/16!QUOT! nickel-plated. My LHS had Great Planes, 4 plus alien tool for just over a buck. http://www2.towerhobbies.com/cgi-bin...00&FVPROFIL=++ If you wont them to match the culler of your linkage thin you mite as well buy two Ofna Servo Linkage kits. http://www2.towerhobbies.com/cgi-bin...?&I=LXBM06&P=7
I hope no one minds the long post. I just wonted to shar my home work because when I asked this question I was told "hear is the link" and I ended up buying the wrong kit the first time.
Hope this helps some one!
ID:	217384   Click image for larger version
802 is offline
Old 01-21-2005, 02:12 PM
Rex2342
Rex2342's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: otee453
It's just like he said.The hardest part was bending the linkage. I just used a pair of needle nose pliers and a pair of channel locks to bend it up.The other hard part was finding a screw to hold the sliders that didn't hit the tvp's. I eventually had to dremal down the plate just a bit to clear the screw.
Rex2342 is offline
Old 01-23-2005, 08:00 PM
802's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I used Piano wier, is that ok?
have had no problems yet.
ID:	219706   Click image for larger version
802 is offline
Old 08-01-2006, 11:34 AM
01sesedan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Which slider did you use for the throttle?
Thanks....
01sesedan is offline
Old 08-01-2006, 01:52 PM
bam.bam
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
HOLY REVIVAL BATMAN!!!!
bam.bam is offline
Old 08-01-2006, 02:24 PM
Gravrober
Gravrober's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
[:-] someone used the search.
Ive got my throttle on the bottom with a home made throttle arm rigged to pull instead of push, I feel this gives me quicker throttle response. The cool thing about the throttle brake mod is you can set it up any way you like. very adjustable.
heres mine.
Gravrober is offline
Old 08-01-2006, 03:21 PM
suicidemachine
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
suicidemachine is offline
Old 08-01-2006, 04:01 PM
01sesedan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What did you guys use for linkage wire? I have some .078 which is I think 5/64" and it does if in the servo horn kind of tight. Guess I could open it up some if I have to. The only thing I'm not able to find is 5/64 collars, guess they don't come in that size.
Here's the list....
1/16" wire
1/16" collars
Ofna Linkage Sliders
This should be it. Let me know if I'm missing anything please....
Thanks...
Old 08-01-2006, 08:16 PM
azzman
azzman's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You dont need any extra linkage wire...just use the stock brake rod...you dont need to bend any Z bends or buy anything extra, just one OFNA linkage kit and one sliders kit and your done. Although I have used a different servo horn the Ofna one can be used easily...or even as some have done, keep the stock one.
But whatever makes YOU happy...
azzman is offline
