wasp .28 flywheel
KS
wasp .28 flywheel
i cant get my flywheel off my s-25 w/o damaging it more than i already have[:@]. what flywheel should i get for the wasp? i need a 3 peg flywheel cause i ordered 3 set aluminum shoes already
VA
RE: wasp .28 flywheel
The vented unit I had tore up.... the pegs mounting was weak. This happened to a friend of mine on his ST also... If you think about it, the venting will drag on the engine (to some degree) if it is really moving air as well...
