What Shock Springs?
RE: What Shock Springs?
if you like lots of big jumps and for general bashing then stick with the stock black springs(hard), all i would suggest is taking out the spacer clips to lower your truck slightly, this will improve handling a lot by lowering the centre of gravity,
also a very worth while thing to do is replace the stock oil with some silicone oil, around 30wt is a good starting point
