oil wt in savage 25
RE: oil wt in savage 25
The stock Savvy uses 10wt oil. I've personally used all the way up to 90wt, but I found that 30wt is good for all around bashing. If your going to keep it on the street most of the time you may want to go a little higher.
PA
i just got 30wt for my savy, and its so much better than stock. the truck now lands with authority and doesn't bounce. it is much more controllable
Yehh. I was using 80wt, but found that it was to stiff off the jumps. If you change from the stock shocks to Al you may want to play with the oil weight also. (+/-20wt)
1 bottle is all you need. Infact you should have a little left over.
Just don't make the same mistake I did. And leave the shafts all the way down when you fill it up. The shaft should be all the way up before you put on the cap.
