Girl in Trouble
AB, CANADA
Girl in Trouble
I seem to be havving some trouble with my HPI Savage the one way bearing keeps slipping I have gone through two and have only ran it twice. I need help
AB, CANADA
RE: Girl in Trouble
Sorry about that, it's a savage ss with a ofna 26. The engine is new but broken in.
i have taken the engine out three times now to check the problem,there is'nt any extra oil on the bearing,it just does'nt seem to grab.
The first time I noticed this was after the engine had died and I went to restart it(rotostart)
Nothing, so I took it home to inspect and dismantle(again)before taking the truck apart for the forth time I tried the rotostart again...it worked.So today I went to try starting it and nothing,I tried to turn the flywheel to variuos positions to see if this would help but it did not.
AB, CANADA
RE: Girl in Trouble
the shaft seems to be ok, I just found that the bearing is cracked,Should I be oiling these things or will that effect the turning over of the engine
RE: Girl in Trouble
No oil.........the Ofna oneway is internal and gets its oil from the fuel..........try to just press the rotostart button for 2-3seconds as these are very hard on the bearings..........you could also try and loosen the glow plug just to give it a better chance to turn the engine over with a little less pressure.
Good Luck
Good Luck
GA
RE: Girl in Trouble
This is why I like my pull starters. I sure here more problems with Roto starters then I do pull starters!
R/C products makes grease that is listed as one way bearing grease. Towers sells or use to sell it.
Is the one way bearing made by Ofna or Roto starter or who ever makes them? I think Rotor starter is made by Hot Bodies but since I do not have or want one I am not sure.
I think you said that one of the one-way bearings cracked how about the other one. Do you have a pull starter for this engine? If so try it and see what happens?
Keep us posted and I will think on it more.
AB, CANADA
RE: Girl in Trouble
The bearing is an hpi model,so is the roto start one bearing was cracked and the other just won't turn the engine over.It just slips.This bearing works in my ofna buggy with the same engine.
As for being internal and getting lube from the fuel? would'nt that create an air leak if the roto start(plastic plate) is'nt sealed??
RE: Girl in Trouble
Usually, you can cure slipping by spraying a bit of carb cleaner on and through the bearing when you remove it. Also, fuels with a high oil content (14-18%) tend to increase slipping. Chances are that with the cracked bearing, the rotostarter was used when the engine was flooded and this put too much stress on the bearing and cracks it.
There isn't an air leak because the shaft that goes through the back plate is machined to such tight tolerances. As it gets overworn, it make leak. Hopefully by that time, you will need to replace or rebuild the engine anyway.
You really can't seal the plastic rotostart plate. There needs to be too much clearance between the plastic housing and the gears to effectively seal it.
GA
RE: Girl in Trouble
If I am not mistaken Hot Bodies makes HPI Roto starter. Correct me if I am wrong. If the bearing works in one engine and not in the other I would say it has to be the shaft. Do you have any way to MIC it? Are you using all the same starter parts on each engine or just the bearing? Do you have a pull starter you could put on it to see if that works? Where the starter shaft comes throw the backing plate there is not a seal so some fuel, which has oil in it gets in the starter compartment. The fuel and oil does help to seal it there. I have 3 HPI trucks but none with Roto starter. Sorry but so far I have never had a problem with any of my pull starters. Keep us posted on what is going on with it. [8D]
RE: Girl in Trouble
Is this the hpi roto start on a ofna engine?? I know the ofna picco 27 one way bearing is inside the engine like stated above. Im sure your engine is the same way... Its actually inside the engine (you have to take off the metal backplate to get to it) right? So basically when you take off the roto start back plate (plastic) you should see something that looks like a bolt head...If you have the hpi roto start backplate on there what its doing is the shaft (bolt head looking thing) is backing out of the engine because theres extra space in the roto start back plate...its ment for a one way bearing and its twice as thick as the shaft. What ya need to do is put some spacers in the back plate so the shaft can not move back. If you have another brand roto start then i dunno. Or like racer man said...u sure u dont have it in there backwards?
ME
RE: Girl in Trouble
ORIGINAL: speedfreak1234
Actually never mind ive just read your "savage sucks" post and i dont feel inclined to help out
RE: Girl in Trouble
GA
RE: Girl in Trouble
ORIGINAL: stanmart
Savage is great. Rotostart Sucks badly.
RE: Girl in Trouble
ORIGINAL: DodamissC
What about just using a drill to start the roto-start like me? works great! drill runs forever too...
RE: Girl in Trouble
ORIGINAL: 46u
Two words PULL STARTER.
ORIGINAL: stanmart
