gearing question..SH28
ok i was looking in my spare parts and i found that i have a 14,15,&18 cb and a 47,49,&52 spur gear, i dont really know how i ended up with them but i have them and want to know everyones opinions on which i should use??
VA
RE: gearing question..SH28
A 17 seems perfect for bashing... guess you'll have to run the 18 that you have. Throw the 14 and 15 out, don't even think about them. I hope you tossed out that POS plastic clutch with the old engine
VA
heh, go on and run it at 15/52 so you can see for yourself why it needs to be bigger. If you don't want to destroy the body/engine head, keep it on grass. [8D]
well i tried to swap the cb to an 18 and couldnt get it to mesh right for the life of me. so i left it at 15/ 52 once i get a new slipper or whatever that thing is called that goes on the clutch, i will swap it to 18/47. thnx for the input[8D]
CA
What method are you using? The paper way or the "feel" way? I got this neat little piece of paper with one of the accessories I got that is the perfect width. I have never broken I spur gear after that. Still have the stock one even with an SH in it. Paper is the best way to go.
I strip spur gears every 3 or 4 tanks and ive used the feel and paper method, my other half has the SS and is still only stripped once.... Ive just been informed that my engine could be running way to hot and softing the plastic that the spur gear is made of, can the actually happen? Anyone ever heard of it happening???????????????
VA
ORIGINAL: ShadeyLady
ORIGINAL: badboy2
im also havin problems meshing the 18/49 combo do i need to change somthing?im tired of wheelies
My favorite option: get a wheelie bar and enjoy them!
