savage top speed?
#178
RE: savage top speed?
Don't tune for temps, use this guide and you will safely push the engine to it's max potential.
http://extremercmods.com/content/tuning-popup.html
#179
#180
I have to ask, you drove off again without resetting your iphone. How did you capture your 51.2mph screen shot? Oh wait you had to edit the video.
My advice is get a clear shot of the number in question. Your last video does not show anything other than a blurry number. If you can get a clear shot.
Dont get me wrong your truck hauls esp for an old one, but the weight of it plays a major role. Im at 12lbs reaching 56, your at 9lbs. It just makes me wonder if my secret I hold is holding me back[&o]
#181
I first one when i got 51.2 i elbowed my friend causing him to lock the phone which ended the vid you can see it is the vid it was hard to even get a clear shot when i was showing u the mph was reset
if u dont believe me which i would understand y (a lot of ppl fake these things) i will make another run sometime soon and ill cut the zip ties while my friend is taping and so u can see it cleary
#182
I showed in the begining of thhe second run that the phone was reset just look really close it isnt that clear but it is there . I didnt edit anything i just put three different vidoes togother
Look close 0.0mph is there on both the first and second runs
#183
ORIGINAL: bertinoj
http://www.youtube.com/watch?v=jXnzMIUUyos&feature=plcp how do u think it sounds here?
#184
Im not hatin on ya dude and yes people fake these runs all the time. I can understand how proud you are at the achievement. It just solidifys it if you have clear proof thats all
#186
yea i understand like i was watching a vid of a dude claiming his xl did 67 with the stock motor i was dieing when i heard this
But yea no doubt i will make some new runs that will prove my claims just give me a couple days because my hobby shop is closed tomorrow and i need a clutch bell
#188
im having a problem right now my gear mesh is set up good i know how to mesh them.... when the truck is flat and spin the spur and the cb nothing slips the mesh is fine now if i was to put 2 tires underneath my front right tire the spur or the cb moves so much that it wont grab i dont no y this is happening ... any info would help
#189
Check your motor plate for cracks. Also check the bearings on the CB. Check the shaft the spur sits on, its common that they get bent. ALso check for any loose or missing screws all over the truck
#190
thanks i just took the motor out and what do u kno a big crack in the motor plate so whenever one tire would go up the motor would shift
Thank you
Thank you
#191
i REPLACED the motor plate and it is still doing it but not as bad now ... i think ir mightbe the shaft where the spur is because when i spin the spur it whobbles like the shaft is bent
#192
Thats is normal, mine does it too on 2 of my savages.
I wonder if your tvps are bent, or you have a missing screw somewhere. You should give the truck a very good look over
#198
I have thought about running rwd but havent tested it for high speed runs. I have ran rwd plenty of times and its much harder to control off the line.
#199
im going to try it tomorrow ill let u no about my results
It seems that it accerlates a lot faster when rolling but i might just be seeing things
#200
What kind of distance does it take you to reach 50?
What I mean is for me I can reach 56mph in roughly 175ft or less. How long would you say it takes you?
