titanium gear mod and reverse mod one in the same or no ?
have *** gear shaft for savage .25 and reverse mod is there a way to make them work together plz be detailed and specific k cuss part 87035c has piece on end havent tried to wrench off yet dont think i can but it wont slide onto the *** shaft did i just waste 30 bucks or is there a way or some other part i gotta get to make this mod work wanted all *** shafts waiting on other two but found this one couldnt be done so any help would be great thanks
Unfortunately, they won't fit. I tried this on my SS and found the titanium shaft is shaped differently than the output shaft on the reverse module (part 87037). On the brightside, the reverse module is nearly bulletproof as is.
dam guess i did waste 30 bones then thanks your quicker then hpi they on vaction lol thought it did show on my 3 speed paper work though how to put it in if you had a *** gear shaft must of been tripping lol it happens you should check out my other post see if you think my idea is any good or not about grinding down an allen wrench for the 2 speed adjustments but thanks alot take care
Your welcome.
