Upgrade engine, upgrade anything else?
NH
Hey i just got a STS 28 engine, for my savage, i wanted to know if there are any parts i should replace on the rest of the truck.
I replaced the spider gears inside both differentials, one of them was stripped so i upgraded to the 4 bevel gear kit. Also some 30K weight oil, keeps the wheels almost locked, Motor saver filter, very easy to clean and reuse, also have a set of prolite mulcher tires. ( studded). Ive been told to upgrade the wishbone shafts. What modifications do you guys think i should upgrade for the best performance. I want to keep it legal for offroad racing at my Off-road LHS track. Thanks guys
Savage SS
STS .28 Nitro Engine
3 speed transmission
Spider Gear upgraded Differentials
Motor Saver Intake
Savage SS
Motor Saver Intake
RE: Upgrade engine, upgrade anything else?
hi rob this is wot i recomend heavey duty dog bones , heavy duty dif cups, heavy duty brake hub, heavey duty drive shafs or bettor still cvs . and 3 speed as the stock trany wont last long mostly its all the drive train that you need and dont forget aly shoes as well. hope tha helps.
BC, CANADA
LCG chassis is the most important upgrade if you race your savage. do you have the dual disc brakes? they are nice! short shock set-up is also good. check www.rockconcepts.net for the LCG chassis for savage.
Which would be a great purchase for my Genesis for racing
Sure Fire .32
3.6hp @ 38,000rpm
for $200
or the
Novarossi Rex .28
2.85hp @ 33,500
for $350
Sure Fire .32
3.6hp @ 38,000rpm
for $200
or the
Novarossi Rex .28
2.85hp @ 33,500
for $350
CA
ORIGINAL: miswa
