Break-in Issues (Idling)
Dear all,
Like many other Savage enthusiasts, I have an idling problem. I ran the first tank, off the ground at the lowest rate I could get before stalling it. The engine stalled several times. I cant get the truck to idle (without the wheels turning). If I turn down the servo throttle the engine dies. This is really frustrating and stressful. It feels like I am going to brake the truck.
How do I get the truck to idle? I don't want to fiddle with the HSN/LSN or the idle adjustment screw. According to the manual I should only start fiddling with these settings after break-in. I don't have a temperature gun, and will not acquire on soon.
Point is, how can I switch on the receiver, and the radio, keep the engine running (before it stalls), put it down on the ground (it will start running forward immediately because it does not idle without the clutch engaged), and start the rest of the break-in? Even if I get the truck to run in circle, when I get to coasting part to cool down the engine, it will stall because I cant get the truck to idle!
Some suggested the throttle trim on the radio. Some suggested the idle adjustment screw, some suggested the LSN.
Thank you in advance for assisting.
RE: Break-in Issues (Idling)
hello m8 i ave to just purchased a savage 25 i had problems with my idle to.
you need to open the carb 1/4 of the way. start the engine and let it warm up a bit then u need to turn the idle adjustment screw slowly clockwise until it is idleing at the correct speed.
the wheels always turn no matter wot and i counldnt find a way to stop them. aslong as they aint spinning rapidly it will be fine
good luck
good luck
MI
Your not going to break the truck. Tune the throttle just before you know it will stall and continue break in. I say let the wheels turn on blocks a little. You do know that if you set it on the ground without the blocks your wheels will stop turning also. ...continue your break in. better tweaking will come with time too
I learned not to sweat the small stuff.
good luck
good luck
ORIGINAL: seef23
Dear all,
Dear all,
