HPI Monster Truck Forum Talk about HPI monster trucks here. The infamous Savage 21, SS, .25 or any other HPI MT. You can optionally discuss HPI in our general MT discussion forum if you prefer.
Anyone Own a Savage X?
Reply
Old 02-28-2012, 11:02 AM
  #7526
sparky 25
sparky 25's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Anyone Own a Savage X?
This past while I stopped bothering with a temp gun,
If you know how your engine should run and sound you don't need one,
You get to know tuning by sight and sound after a while.
sparky 25 is offline
Old 02-28-2012, 12:54 PM
  #7527
nitro-rob
nitro-rob's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I completely agree.  Temperature is a good way to get started and it can be a good guide but after a while you can develop the ability to tell by ear.  Sometimes the engine can sit at 240 or so and still be rich and will run best at 280 and some days it runs best at 220 and can't go any leaner.
nitro-rob is offline
Old 02-28-2012, 06:37 PM
  #7528
1ne8ighty2wo
1ne8ighty2wo's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I love that bug body! I found a couple on ebay, but it looks like they come in long chassis and short chassis versions (details below). Which would I get to fit a Savage 21?
Long:
Length: 19.25" (489mm)
Height: 6.0" (152mm)
Width: 7.5" (191mm)
Wheel Base: 12.5" (318mm
Short:
Length: 17.63" (448mm)
Height: 5.75" (146mm)
Width: 7.0" (178mm))
Wheel Base: 11.38" (289mm)
1ne8ighty2wo is offline
Old 02-28-2012, 08:22 PM
  #7529
SLAYERDUDE
SLAYERDUDE's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My "member" best fits a Savage body, in length and circumference.
That's your best bet, from what I have been told.
SLAYERDUDE is offline
Old 02-28-2012, 11:57 PM
  #7530
quietnas1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: 1ne8ighty2wo
Long:
Length: 19.25'' (489mm)
Height: 6.0'' (152mm)
Width: 7.5'' (191mm)
Wheel Base: 12.5'' (318mm
Short:
Length: 17.63'' (448mm)
Height: 5.75'' (146mm)
Width: 7.0'' (178mm))
Wheel Base: 11.38'' (289mm)
I actually got the Pro-Line baja body for the Revo. It was a perfect fit.
quietnas1 is offline
Old 02-29-2012, 08:05 AM
  #7531
1ne8ighty2wo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just to be sure, you have [link=http://prolineracing.com/bodies/volkswagen-maxx-revo-body/]THIS ONE[/link], right? What model Savage do you have?
Old 03-01-2012, 08:50 AM
  #7532
quietnas1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yup that's the one.
Old 03-03-2012, 04:13 PM
  #7533
1ne8ighty2wo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So I have all the parts I need for my Savage and I finally got a chance to start it up yesterday. I found that the fuel tank pump doesn't work so I had to blow in the pressure line to get fuel to the carb then plug the pipe and run the roto to prime it (is this an okay method, and any easy way to fix the fuel pump issue? Besides buying an in-line primer bulb, which I might have to do). It started up after a minute or so of working at it so I took off the starter set it down for about 20 seconds of idling pretty consistently, then as soon as I tapped the gas it cut out. This happened a few times so I left it for the night and came back to it today.
It started up the same, but now when I take the starter off it dies after about 5 seconds, and it only goes for 30 or so seconds before it slowly dies with the starter still on. Is this a matter of it not being warmed up, or does it sound like something else? The needles are at factory settings.
I had some problems with the carb in getting the needles back to factory settings, does it sound like it could be damage to the carb/needles that's causing this?
Old 03-03-2012, 04:38 PM
  #7534
echthelion
echthelion's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
sounds way rich lean the HSN
echthelion is offline
Old 03-03-2012, 07:51 PM
  #7535
ThunderbirdJunkie
ThunderbirdJunkie's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If your Savage has the primer tank, then it's probably pushing a decade old. The primer tanks were done away with because the primers leaked and - you guessed it - tuning issues. Get the primerless style tank and you should be good to go.
ThunderbirdJunkie is offline
Old 03-03-2012, 11:28 PM
  #7536
1ne8ighty2wo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I believe I found my problem: the threading for the glow plug has somehow almost fully stripped out of the engine case. Is there any way to get this re-threaded, or does it look like I'll be buying myself a new engine?
EDIT: after looking on tower, would it just be a matter of buying a new [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXDLM6&P=Z]UNDERHEAD[/link]? I can't tell if that has the threaded part or not on it
Old 03-03-2012, 11:55 PM
  #7537
echthelion
echthelion's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yes thats what the glow plug threads into just make sure that its the right head for you engine
Old 03-04-2012, 12:10 AM
  #7538
1ne8ighty2wo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: echthelion
Thank you!
Quote:
ORIGINAL: ThunderbirdJunkie
Oh wow, thanks for the info. Do you know if a tank for the savage x would fit in the savage 21?
Old 03-04-2012, 04:05 PM
  #7539
ThunderbirdJunkie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yep, in fact that was a running change back in the Savage 25 days. The updated tank will fit no problem.
Old 03-05-2012, 09:58 PM
  #7540
1ne8ighty2wo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: quietnas1
Hey everyone. I don't pop in here much cuz my Savage is pretty much trouble free. I do need a little help deciding if I should paint my frame red or keep it stock. Here are a couple of pics let me know what you think. Thanks.
Did you cut any wholes in the body for air flow? And if so, where?
Old 07-06-2012, 06:43 PM
  #7541
smush81
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
backstory:
i bought my rtr savage x 4.6 last year. ran it a few times with little to no problems. broke a shock and it sat for a while (few months) due to just being super busy. finally got it back up and running again the other day and was running great. from what i could tell everything was tuned just fine. ( this is my first nitro truck) put it away for the night. the next day had problem with the throttle servo holding wide open as soon as i turned it on. figured out it was a problem with my stock remote. bought a new remote (spektrum dx3c) and replaced the old reciever with the new one that came with my new remote. took it out and ran it for about 5 mins before it stopped moving the wheels. turns out screws in motor came lose and it missaligned with spur gear, destryoing it. I replaced it, thread locked screws back in, and ran it again. now i cant seem to get it to consistantly change gears. this is my current problem i need help with. it will sometimes switch and other times it just revs really high in first without changing to second. i know there is a screw i can adjust to change shift points but im not sure this is the problem since it will still occassionlly shift. been cleaning,adjusting,and tuning it for 2 days now trying to get it running right with no luck. checked clutch shoes and they seem fine. dont really have much experience with them but i dont see any excessive wear on them so im assuming there ok. spur gear is still good and mesh seems just fine. any suggestions would be great. sorry for the long backstory but i figued if u had all the info it might help. also after checking the clutch shoes i cleaned out the clutch bell just to make sure there wasnt a grip problem there. still no luck. suggestions? thanks!
smush81 is offline
Old 07-06-2012, 09:12 PM
  #7542
SLAYERDUDE
SLAYERDUDE's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Start with the tune, if you are too rich or lean it won't shift properly.
Old 09-04-2012, 08:56 PM
  #7543
xDIRTYSOUTHx
xDIRTYSOUTHx's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My Savage X 4.6 got here this afternoon and all I can say is DAMN!
Going to break it in this weekend and can't wait to bash this beast. My XS looks so funny next to it..
xDIRTYSOUTHx is offline
Reply
Display Modes
