backplate screw is stuck
alright well i just got my t-maxx big block conversion all set up so now i want to put my big block on there. i would put my collari .32 on there but i have to get a new piston and sleeve. so i am gonna put my xtm engine on there. so i put that on there and i cant get it started. so i want to put my s-25 on there because that is a nice engine. well i was trying to take the back plate off to see if the xtm backplate will work because the s-25 has the shaft coming out and the one way is shot so i was gonna swap backplates from the xtm to the s-25 so i can use the engine. well anyways one of my screws is stripped out and i cant get a alan wrench to get it out.. so what do i do to get it out? thanks
RE: backplate screw is stuck
crap.. i should have remembered that trick.. to late now. i took the motor to my bros and he is gonna weld a little bit on the screw and then use some pliers and just twist it out.
