@Nyc/NJ people.
@Nyc/NJ people.
This post is geared to New York City/New Jersey drivers, I'm looking for a hobby shop that might carry this item so I can go and pick it up. I'm not up for waiting for it to be mailed to me I'd rather go and get it myself.
http://cgi.ebay.com/HOT-RACING-HPI-S...QQcmdZViewItem
My Feedback: (13)
RE: @Nyc/NJ people.
try crispycritters they might have it.. call them first ..they carry a lot of hop ups for most mts..
[link=http://www.crispycrittershobbyshop.com/]HS INFO[/link]
got tired of your spur being stripped everytime?are u sure theres nothing bent ?maybe try changing the tvp's ..
RE: @Nyc/NJ people.
The truck was taken apart and my engine mount plate had a slight crack, tvp was warped both were replaced I still go through spurs. So I figure enough is enough and it's time for a change.
My Feedback: (13)
RE: @Nyc/NJ people.
jojosracing i think is in south amboy in rt35 unless they have another store..anyway i was like that on my previous savs ..i kept stripping gears ..i guess the truck will adapt to itself after a while,coz i never stripped one anymore ..what tvp do u have now?do u still use stock cb?
My Feedback: (13)
RE: @Nyc/NJ people.
u need to replace the x tvp i guess ..from what ive been reading in the forums theyre not that good ..and an unnoticeable bent will give u bad meshing..try putting flm chassis...it looks more tougher and it is lcg..
RE: @Nyc/NJ people.
I have the same problem but only when using my WASP 26 engine. 3 SG srtips!! At $5 buck a pop, I went with a GH alloy/steel 49T SG and Racers Edge 18T vented CB.
The strange thing is when I drop in a different motor, the plastic spur doesn't strip at all using stocj CB. The other motor I have are XTM 24.7 and XTM 24.7 Pro.
I changed gears over this past weekend. Had an outing Sunday and push my truck hard as I can expecting the vented CB to strip but everything held nice and tight.
I gonna try switch to a stock cb to see it it will strip with the steel sg. Just curious... I have alot of stock cb's. Ventedcb are not cheap as the stock one..
RE: @Nyc/NJ people.
ORIGINAL: badboy2
ive used wasp26 and picco26 on my sav and i never had problem with the stock SG..but i only have the s25 not the X..
The best guess I can think of is my Wasp 26 motor reaches the higher prm range so fast it just heats up the cb no matter what clutch system I use. [:@]
It wont grab hard enough. I do have a set of Werks 4 shoe clutch I like to try. However, that uses carbon shoes as well. I have mey doublts but we'll see.[X(]
