Orion CRF V6 clutch
CT
Orion CRF V6 clutch
i have this clutch as u know from my long privious threads and now i have a question (again). i got the purple nova ajustable mount and everything works perfectly. the only thing is to get it to engage at the right time, it needs to be LOOSER than flush with the pilot nut (clutch nut) is that ok? i only have 1 shim at the front of the clutch bell and 1 shim behind the clutch bell. the shim behind the clutch bell touches the adjustment nut, not the clutch not. if i make it flush it engajes too lat and very rough.
CT
RE: Orion CRF V6 clutch
yea so what do u think? it needs to be LOOSER than flush with the pilot nut (clutch nut) is that ok? i only have 1 shim at the front of the clutch bell and 1 shim behind the clutch bell. the shim behind the clutch bell touches the adjustment nut, not the clutch not. if i make it flush it engajes too lat and very rough.
Here's two links to people who have tried (or had probs) with this clutch.
http://www.savage-central.com/module...wtopic&t=61453
http://www.savage-central.com/module...ighlight=orion
hope this helps
hope this helps
Ooops sorry, my bad
savage central>savage hop ups>orion v6 clutch
savage central> savage help>crf v6 problem
This is where these articals are located if you can find without being a member
