Savage 4.6 ss build**PICS**
Hay guys.
Just got a savage (kit) a few days ago.
So I thought i would show you guys some pics of it so far....
If theres anything wrong that you spot, can you tell me, thanks.
RE: Savage 4.6 ss build**PICS**
Yeah, Crowd Pleazer 2.0 would sure be nice.. Not only nice-looking, but functionally nice as well I hear..(as in tough and offering extra protection..)
Thanks for your coments...
SavageMan- I'm pritty sure the savage X body fits good, so im going to try that.
Amwhite- yeah they should be good for bashing, But i'm going to try and race it a bit.
Badboy- Yeah thats a FLM shassis
Also I have a question....
How do you brakes work?? With the extended shassie, I have to have a longer drive shaft.
And thats mucking up the brakes i think.
I'm not sure if ive done something wrong with them.... But every time i spin the spur gear,
the brakes lock on.
And also, How do the brakes conect to the servo lol.
Thanks again
If you need any more pic's of the brakes, Just ask.
the brakes lock on.
Thanks again
Also I can't get the little rod things into the place where the hex nut go's......
Have i done somethink wrong here, I put them left to right, but still no differnts
Thanks again
Thanks again
NC
Looks great!
You get extra points for going all the way and using the extended arms with the extended chassis. I'm with 46u on the extended chassis part, but the arms compliment it very nicely.
The servo connects to the arm that mounts on the side of the transmission, and that arm activates the brake cam which clamps the pads onto the discs. Look in the manual.
I'm not sure what you mean by the "rod that goes into the hex thing".... clarify please?
Ill get some pics when i get home...
But ill try to explain now..
OK. I'm not to sure of the name of the part, but where the mettle are, where the wheels go onto,
Theres a little mettle rod that stops the wheel from spinning around. and also stops that mettle
part from falling out.
But when I try to put that rod in, it will not go in the hole.
Have i done something wrong???
It's like the mettle bit isn't out far enough.
Thanks again
Thanks again
NC
Can you reach behind the hub and push the axle in further so that you can insert the pin? I've never run into that problem... sorry.
How many inches did u add?? i really like those TVP from the looks of it u added 2 inches right??? can u still use the roto start with it???? let me know i wanan get a set soon
Hay guys.
Just some more pic's.
Ive nerly fished it, I just have to install the radio gear.
Oh and figered out how to set up the brakes
make sure the bearings that go on the inside of the upright set are properly seated otherwise you will find it hard to seat the pin for the hex.
Here just another pic i took...
I'm hoping to get the radio gear and servos for it soon, than I can run it in[>:]
