Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Monster Trucks > HPI Monster Truck Forum
Reload this Page >
Savage X - Sudden lack of performance - Part I
HPI Monster Truck Forum Talk about HPI monster trucks here. The infamous Savage 21, SS, .25 or any other HPI MT. You can optionally discuss HPI in our general MT discussion forum if you prefer.
Old 09-01-2006, 05:46 PM
ViperX
ViperX's Avatar
Default Savage X - Sudden lack of performance - Part I
hello fellow truckers
this is really strange wots hapenin to my truck. today i decided to retune my engine. so i set the carb back to factory settings and starting to retune. everythin was going fine. after 10-20 mins the truck started to build up some good speed. healthy smoke coming out, timely gear shifting, good sound etc.
then suddenly my truck gets real slow. no matter how much throttle i give it. it runs but very slow. at first i thought i stripped my spur gear. but the spur gear was fine. so i took the WHEELS OFF THE GROUND and gave it some throttle and it seemed perfect. and ON FULL THROTTLE, ALL FOUR WHEELS MOVED FAST ENOUGH TO MAKE WHEELS GO THIN. but when i put it back on the ground, it doesnt move fast at all. what going on here.
so far i checked:
--transmission<<<<<< near enough brand new
--set screws<<<<<<< they all seem to be there
--spur gear<<<<<<<< all good
--fuel tank and pipe lines for any leakage - none found
plz plz plz - somebody out there - help me out
UPDATE 3(1) - August - 2006
-- took both front and rear diffs apart - no damage
-- dropped engine in my other truck's body - runs fine(so my engine's clutch bell, shoes are fine in that case)
-- slipped pads
UPDATE 3(2) - August - 2006
i really appreciate all u guyz who have posted and tried to sort my truck out but unfortunately its just not hapening. so i ve given up for now - i guess this is part of the hobby we r in to - i will try again next weekend and try fixing it. also appreciate the idea of taking my truck up to my lhs but i really dont think thats a good idea as they are known to do more damage than any good. atleast mine are.
i plan to rip the whole truck apart for next weekend and reassemble it( a very unnecessary move but i m left with no other choice - this is pure madness). hopefully i will come across problem and fix it along the way.
amwhite2005
i checked my slipper pads as soon as i read ur post - i was really hopin that was the cause but they look good as new. the tranny case is immaculate. the truck is only 4-5 months old and well taken care of.
THERE WILL BE A Savage X - Sudden lack of performance - PART II with pix and actual video of how my truck is when on and off the ground(hopefully that would help all u tryin to help)
Old 09-01-2006, 05:54 PM
Revo Eater
Revo Eater's Avatar
Default RE: Savage X - Sudden lack of performance
Just a guess. Are the reciever batteries dead?
Old 09-01-2006, 06:04 PM
ViperX
ViperX's Avatar
i wish they were and that was causing the problem.
Old 09-01-2006, 06:20 PM
savvyjj
savvyjj's Avatar
What about the cluch shoes after a while they wear down and then it doesnt spin the cluch bell very well
Old 09-01-2006, 06:35 PM
bennyblanco
bennyblanco's Avatar
check your diff gears,the little screws that hold the cvds and your clutch shoes thats all i can think of right now good luck!!!
Old 09-01-2006, 06:59 PM
SAVAGEJIM
SAVAGEJIM's Avatar
Be sure to tune for the changing temp and humidity conditions. I do not know if the humidity varies from day to day in London, but if it is humid one day and dry the next, you may have to resort to tuning by changing plugs.
It's really simple. For humid days, switch to a hotter plug and then retune the engine with the needles. If the aid bvecomes dryer, switch back to a medium (or colder plug) and again, tune the needles to the new plug.
Aside from that, be sure to check what everyone else is suggesting.
Old 09-01-2006, 07:37 PM
ViperX
ViperX's Avatar
wot i dont understand is that when the truck's wheels are off the ground, the clutch engages fine and wheels spin mad fast at full throttle. its like its got no diff, transmission, clutch or acceleration issues whatsoever. its when its on ground it starts getting sluggish. really sluggish. its makin me go flippin mad - i cant pin point the problem. i kno for sure someone here has the answer to my prayer.
Old 09-01-2006, 07:57 PM
pulse213
ORIGINAL: Revo Eater
That was my first guess.
Had one do this once. Took the carb apart,blew nitro cleaner through it,put it back together and it ran fine. Must of had crud in the needle and seat.
Have you made sure your getting full throttle? Sometimes those carbs stick.
Old 09-01-2006, 08:17 PM
ViperX
ViperX's Avatar
yes the carb is opening up and i am getting full throttle hence the reason why the wheels are spinning like they should when wheels off the ground.
Old 09-01-2006, 09:44 PM
a8man
This is about the same as what was happening to me but mine would not climb at all. Did you tighten the slipper clutch screw? I usually tighten it all the way then back off 1/4 of a turn but most run it tightened all the way. So try it!
Old 09-01-2006, 10:46 PM
pulse213
ORIGINAL: ViperX
Did you pull the breather and look?? You can get the tires to balloon at 1/4 throttle when they're off the ground. Hense the reason I asked.
Old 09-02-2006, 03:55 AM
ViperX
ViperX's Avatar
ORIGINAL: a8man
i will try that
Old 09-03-2006, 07:40 AM
ViperX
ViperX's Avatar
i tried all the above and with no lucky i am still at the same place with a sluggish truck. having 2 savages help though i must admit. i put the engine in the other truck and its flies like a rocket so atleast i kno i dont have any clutch shoes or clutch bell issues.
Old 09-03-2006, 07:43 AM
amwhite2005
Havent stripped your wheels have you?
Lost the pins that go into the hexagons that power the wheels?
Old 09-03-2006, 07:49 AM
ViperX
ViperX's Avatar
the hex and pins are intact
Old 09-03-2006, 07:52 AM
amwhite2005
Are your dogbones still intact?
The other 2 gears by the diff (13tooth and 43 tooth)?
Sorry for the obvious, but i'm running out of ideas, hope you get it fixed.
Old 09-03-2006, 07:56 AM
ViperX
ViperX's Avatar
tell me about it - i ve spent nearly all day lookin for the problem. its really stressin me out. its never taken me this long to find and fix something. its just ridiculous.
Old 09-03-2006, 07:58 AM
amwhite2005
did you check your dogbones and the other gears I mentioned. I presume you still have 4WD?
Old 09-03-2006, 08:04 AM
ViperX
ViperX's Avatar
checked all. and yes i m 4WD. i think i m gonna chuck my truck outside the window
Old 09-03-2006, 08:10 AM
amwhite2005
Might fix the problem...
Does it make any strange sounds when you run it on the ground? Any grinding or anything. I dont know if the pipe will make any difference, has it cracked or anything. I had a pipe crack on me and it really dented performance.
Is the tranny case imaculate? It hasn't cracked or anything? The bulkheads and diff housing are all fine? Drive cups showing any sign of wear?
A big guess, but nothing else is right...Have the tired come unstuck from the wheels? (Very unlikly, but I suppose it could happen, but you would have probably noticed it)
Is the slipper pad toast?
Old 09-03-2006, 08:20 AM
steve9000
if uve tried all of these methods i suggest u take it 2 ur lhs and see wot they make of it, tell em that uve tried all of these methods. hope this helps
Old 09-03-2006, 08:24 AM
amwhite2005
I cant think what the LHS are going to think of. Here you have the knowledge of the World, they only have the knowedge of years experience, which most of the people here have. They will just go through everything we have said. How old is it, if it is under a year then they have to do something, and if they cant find the problem then they should give you a new one.
Old 09-03-2006, 09:25 AM
BigBoyLST
try replacing the fuel line just in case, because mine was slow like that and once i changed the fuel line it wheelies like crazy
Old 09-03-2006, 11:25 AM
bashncrash91
i think its your clutch. this happened to me with my tmaxx...
Old 09-03-2006, 12:26 PM
Sparco
Sparco's Avatar
when it's on the ground and you bring it to wot (on the tx) does the engine go to wot?
