RED THREADLOCKER
RED THREADLOCKER
I have 1 bolt that keeps coming out, I keep using blue threadlocker but it still comes out. Could I use red (permanent strength) on this 1 bolt or am I asking for trouble?
trev
trev
RE: RED THREADLOCKER
ORIGINAL: benzzyo5
which bolt is it
which bolt is it
If its it Z613 that screw into the alum square shaped chassis braces that are scred under the engine mount plate, I guess using red on them is okay. Those come off all the time from the amount of engine vibrations. I too have problems with those coming off all the time. Before doing anything this drastic, I would check the alum braces and make sure it is not a thread problem that is causing the screws to come out. If they have effectively lost their threads, thread lock, no matter what color, will work. Even JB Weld will eventually fail if the threads are gone.
Now, if the the screw that keeps coming out is either Z632 or Z567, thread lock will no help at all since these scres are coming out because the plastic pieces they screw into have basically lost their threads. This is way simple to fix; replace the plastic part that they screw into. You can put a drop of thick CA into the problematic plastic hole, but this is only a band-aid. The screw will eventually back out again.
Another bolt that likes to come out often (again from engine vibration) is Z792. These are the hex bolts that bolt the engine mount to the engine mount plate. Once you get your engine in proper position such that your mesh is correct, thighten these screws down as hard as you can with you hands. Then, tighten them down a further 8th turn with pliers. This will gauranty they will never come out. When you need to do maintenance such that it requires removing the engine mount, you will have to use pliers again to lossen the Z792s.
Its a M4by15mm that goes into the integry chassis brace bar ( looks like running boards on the truck ) i also did swap out the stock plastic piece and replace it with the metal ones so it is metal to metal, and its the one closest to the engine. I dont think you need to take that bolt out to often
trev
trev
OMG the red thread lock is permenent!!!!!!!!!!!!! oh man i might never be able to take the engine off my revo ever again.................................is there any way to take it off?????????? sorry i dont mean to highjack the thread
LA
DEE DEE DEE!!
ORIGINAL: MiamizFinest
ORIGINAL: savage.27
DEE DEE DEE!!
DEE DEE DEE!!
LOL yes today i em the DEE DEE DEE.......LOL
u used the locktie on the engine mount so its metal to metal ..........the day i wanna take it off ill make sure i got my torche in hand LOL
i use a small drop of red threadlock on all my metal to metal screws but not to much cos then they become very hard to get out and can end up rounding out the head.
