one way bearing problem
basically what I am asking is, are one way bearings a one size fits all application. here is my dilemma, I have a x factor with the 24-7 engine with pull start and I know the one way is out, I also just put a new engine in my savage. will the one way out of the savage 25 fit the xtm engine? if not where can I get the one way for my x factor, lhs said he could not help me[:@].
CA
RE: one way bearing problem
1 way bearings are finikey, spray a little brake cleaner/motor spray through the pull start rope and it oughta catch. The bearing seeps a little oil out and gets slippery. Happens all the time, even with new bearing. No need to change it out.
Brake cleaner or wd-40 will get the OWB to bite if it's not shot...
Here's where you can get all your XTM 247 engines parts...[link=http://www.hobbypeople.net/part/146027.asp]XTM 247 Parts[/link]
A OWB for the 247 is $19.99
if you pull off the back plate to clean the one way.
you can put an o ring on the shaft to hold back the oil
coming out of crankshaft. i used that trick and my one way is still grabing
after 2 gallons.
after 2 gallons.
I did that for a while, and indead it did stop it slipping. But I found that the OWB went bad quicker (dont know why), but I went through 2 in 2 Gallons, whereas they normally last over 2 gallons with the same one.
