Tire diameter -->O
Tire diameter -->O
Last thought on tires. The rims I am using have an outer diameter of 89mm.""moab 40 series XL'' the tires I want, have an inner diameter of 91mm. Will this work or will the tires be too lose to glue to the rim? Has any one done this or am I the Gene-Pig.[sm=bananahead.gif]
MI
RE: Tire diameter -->O
Them fit Pro-line 40 series Narrow wheels only.
like these http://www2.towerhobbies.com/cgi-bin...?&I=LXLPW9&P=V
ORIGINAL: bumperdragger
I don't think they are going to work.
They will not work at all........ .. 3mm is alot when it comes to it... That;s like trying to thread a nut meant for a 10mm bolt on a 7mm bolt... Measurements are done for a reason and it's just that simple....
Good call bumper...................
