Savage X SS 4.6 run time question...
NY
I have looked at many places and have not been able to find this for some reason but how long will the Savage X SS 4.6 last on one tank of gas, also is it bad to run out of gas, because I have read that it isnt that bad for cars?
,thank you
,thank you
MO
RE: Savage X SS 4.6 run time question...
I get about 20mins out of my savy,it's a savage 25 with the x motor,but i would say it depends on how good you can tune your motor, theirs a fine balance their,a balance i'm still learning how to optain,and also you'll hear alot of ppl say back and forth about running out of fuel,the pros and cons,but all i know,dont let your motor sit with fuel still inside,let it burn it out,they say the fuel will cause rust,and that leads to all kinds of problems,me i let it run it all out,then add some after run oil and cycle the motor with the rotor start to lub it all up,maintains a healthy motor longer.
ORIGINAL: supermotoxaustin
,thank you
,thank you
--RCNZ
On my S-25 engine, I get 40 mins everything stock. Its so long I usually dont have the time to finish a whole tank A lot of people my be skeptical but I blame my really good tuning skillz[8D]
My friend who recently purchased the Savage Xss 4.6 gets around the 10-15 minute mark from a 3/4 full tank so your probably looking at around the 20 minute for average driving. everything stock.
Try and get in the habbit of bringing the car when its low on fuel and topping it up while the truck is running.
running in to empty on the final run is fine aslong as you know your getting low on fuel and not gunning it full noise down the track. put some after-run through it to keep it healthy, and dont leave fuel in the tank while stored.
GA
ORIGINAL: rcnitrohead
Ya right! [sm=spinnyeyes.gif]
ORIGINAL: 46u
