engine locked at TDC.
NY
RE: engine locked at TDC.
ORIGINAL: someguywitasavage
thats a common problem with the hpi carb, you will most likely need a new one. Dont get the same one again or it will happen again. Im not 100% sure but i think a good replacement is the mach 26 carb or so i've heard. Can anyone confirm or deny this?
ORIGINAL: buggymangp
no matter how tight i try to lock down the carb. its still loose.
i'd go with the sportwerks carb
sportwerks http://www.horizonhobby.com/Products...ProdID=SWK8008
mach .26 http://www.horizonhobby.com/Products...ProdID=DYN0909
hey guys
my x is up and running again.
i was able to pick up a other carb body from my lhs
last night. the locked engine is a thing of the past.
i guess the locked engine was from the carb running it rich.
i ran about 1/2 tank thur it in front of the hobby shop and my back yard
last night. starting it and shuting it down a few times and it never locked up once.
thanks for all your help guys.
NY
did u get the same carb but u got just the body part? thats a dumb buy, it's just going to happen agin. i bet u paid somwhere between20-30$ u can get alot better one for 35$
hey b
yea i got a carb body that fits. cost me 28$. i did get 4 gallons of use out of the stock one.
so if i get other 4 gallons use out of this one. or the engine. i`ll be fine with that. after that i`m going for a new engine.
also this is the last time i rebuild stocks too. next time i bend shock shafts or shocks start to leak. i`m going for upgraded
shocks .
shocks .
#31
hey guys
just an update
i ran my savage this weekend after my carb problem.
i got it running great. no more engine lock. only now i got other problem.
i was running the truck WOT and i ran right into my field box. DOH.
bent both front dogbones and pulled out both front lower a arms.
but at least i can say its running great.
just an update
