Hitec HS 645MG help! :S
I need more of those screws which hold the servo horn down. You only get one with the servo and the head is pretty messed up on mine so i want to take it out and put a new one in.
I've asked before and someone said these are the screws i need:
http://www.hpiracing.co.uk/piw.php?lang=en&partNo=z481
But the thread on the screw which came with the servo looks more like this:
http://www.hpiracing.co.uk/piw.php?lang=en&partNo=z431
Does it matter which one i get?
Please reply
Please reply
RE: Hitec HS 645MG help! :S
ORIGINAL: joes75
The ones in the second link are the correct threads, the ones in the first link are for screwing into plastic.
This is from the savage ss instruction manual, it says for a metal geared servo use the screws that in your second link...z432 is the part #.
Shouldnt it be Z431?
Can someone please just confirm, surely someone has replaced a HS 645MG screw once in their life for the stock Savage 25 steeering horn.
Please reply.
Please reply.
NY
http://www2.towerhobbies.com/cgi-bin...?&I=LXDEN5&P=7 get these. thre's 10, 5 are 2.6 times 8's and 5 2.2 times 5's, i think the bigger one goes on it. but i'm not sure just see whitch one fits. don't wrench on it so u strip the out put shaft on the servo go easy ond one will fit.
ORIGINAL: benzzyo5
