Savage x Brakes
VA
Savage x Brakes
Greetings all. I recently acquired a Savage x and have completed the breakin process, and tuning. However I seem to be having problems with my brakes. It seems even with the screw attached to the arm, screwed all the way in, all it does is slow the car down a bit. It doesnt even come close to stopping it. any suggestions? Your help is appreciated!
ON, CANADA
RE: Savage x Brakes
hello i had the same problems with my brakes i just wouldnt come to a stop i tryed everything, i just got fed up and i bought aluminum dual disc brakes and they work amazing.
NY
RE: Savage x Brakes
^^^ what would steering have to do with te brakes? anywauy i would do the ofna throttle mod, it gives you quicker throttle responce and better braking. also get a hump pack it will help out a little
CA
RE: Savage x Brakes
I added fuel tubing, but before I did that (didnt have any with me) I loosened the set screw that holds the linkage, then pushed down the rod about 4 mm.
NY
RE: Savage x Brakes
ORIGINAL: Savage X Driver
My bad sorry about that i meant the throttle servo sorry about that. it worked for me.
no problem, just lookin out
