break in
QC, CANADA
break in
i just got a savage xss and i built no i just need to break in the engine but it well below 0 out i ran two tanks through it in my garage by putting tube on the pipe and running it outside but is there a method that i could use to break in my engine completely without bringing it outside?
NY
RE: break in
really there's no other way, unless u ask walmart to break te truck in the store........lol. if u know sombody that owns a ware house. my dad knew sombody and i broke in my fist nitro there
NY
RE: break in
as long as u keep the temp up your fine, put tin foil around the head and put a sock around, pre-heat the engine to about 190-200, then start it up, and try ti keep the temps abouve 190,
RE: break in
I partially ran my other car in in my conservatory with the door slightly open. Well to be fair i only really started it there and left on idle for about 5 minutes before taking it outside. Man the echos from the engine in a conservatory are LOUD!
IL
IL
RE: break in
ORIGINAL: benzzyo5
yup, also alwys put the piston at bottom dead center when it's not in use
NY
RE: break in
what i do it, take off the exhaust amnifold. look into the port put the piston at BDC then i make a mark on the fly wheele that indicatesd the bottom. so everytie i'm done i rotate the fly wheele in the same posistion, and mark the wheele with a sharpie, so u can see it.
IL
RE: break in
ORIGINAL: benzzyo5
IL
RE: break in
ORIGINAL: benzzyo5
thanks i do it like this so u can get the very bottom, it's confusing to explain but it works pretty easy
NY
RE: break in
yup thats exactly how i have mine facing the exhaust, u might want to make it a little wider, because as soon as i shut my engin down i put it at BDC, it makes it easer to se if youtr out side or somthing
RE: break in
i would break it in outside but wrapp the engine head in aluminum foil and heat up the engine with somthing like a hair dryer ask people about heat cycling for your engine it is the new break-in method
NY
