k 4.6 engine carb
k 4.6 engine carb
sorry to bother you guys im having problem taking off the carb of my k4.6 engine i took off the carb pin lock(screw) but there is a black thing that holds the screw inside do i need to take it off aswell?im trying to push both ways but nothing happens...please help...[&o]
RE: k 4.6 engine carb
Put the screw back in one or 2 turns and give it a light tap, it will push the threaded side out, the other should almost fall out, its in 2 halves.
