Runnin rich?
NV
Runnin rich?
I've got a xss, k4.6 while breakin' is was way to rich. took my almost 1/2 gal to tune. My ? is was runnin it rich for that long (temp never got above 200F) gonna have an effect on the engine? i'm able to get it up to temp 220 - 250F now. but when I try to pull start (warmed up engine) it seems to have no compression. I hope I don't have to replace the internals
RE: Runnin rich?
ORIGINAL: LVRC
Breakin in is very important as it strengthens your engines components (tempers).
If you never got above 200F then you are looking at an engine that will run for many gallons, but without the performance it should have. A LOOSE feeling engine (no compression) is a sign of a worn sleeve and/or worn piston. In most cases with this it is due to break in done not reaching at least 200 or more degrees. The brass sleeve is plated and it needs to expand with the block to prevent wear in the "pinch zone" which is TDC. When you lose the pinch it causes lost compression and less performance from the engine..
However, for a poorly broken in engine you can expect at least 3-5 gallons or more before having to rebuild it. Providing that's the case that is.......
Next time you break in an engine USE this method and NOT the INSTRUCTIONS.
[link=http://www.phpbbserver.com/rcworld/viewtopic.php?t=754&mforum=rcworld]HEAT CYCLING DONE RIGHT[/link]
RE: Runnin rich?
I'm getting ready to re-sleeve mine (air filter came off and sucked in some *****). This sounds like a great idea the question i have is do I put the LSN and HSN back to flush for this method or just leave it at the somewhat tuned settings i have now and break it in from there and then tune it again.
RE: Runnin rich?
ORIGINAL: XtraLgThumbs
TX
RE: Runnin rich?
