Hpi X or SS?
MN
RE: Hpi X or SS?
I have seen stock Savage X pull wheelies on videos, but you have to remember that you have to tune tthe engine properly. And the 3 speed will work good in both, it provides more torque and higher top speeds. If you want convinience and to not hassle with picking up servos and radio equipment go for the X, but if you are willing to put it together and put time into buying a quality radio and servo go for the upgraded X SS. Go to www.hpiracing.com and check out the X and the X SS and see which you like best. You can also go to www.towerhobbies.com to compare them and buy it if you like. Hope this helped!
