how to make yur savage higher
just wondering hw to make yur savage have more ground clearence ie jack it up,body lift eny part numbers to make this happen or part numbers and description thanks.........scott
RE: how to make yur savage higher
If you can find um or make um you could make extended a-arms and longer shocks. Thats my only idea for making a savage higher. Y did u wanna make it higher in the first place those things already tower sky high.
Use more shock clips
http://www2.towerhobbies.com/cgi-bin...&I=LXDLC7&P=ML
I use 1/2'' pvc pipe cut to 3/4'' pieces c-notched and painted black I ride 3 1/2'' in the air ant hills are no problem so ants beware! Ohhh soak the pvc in hot water so it does not snap
^^^ I want some jumbo kongs but my 7'' are all ready chewing my diffs up bad[&o]. you can run 8.5'' tires just don't jump them.
CA
that would be nice if you could make it higher off the ground with the stock wheels.cause 3 inches is not enough,plus the savage looks like a girls car when under 2 inches off the ground(unless your racing) imo.one thing i have thought about doing is trimming the aarm or the bulkhead to gain more clearence.but i got rid of my savage before i tried it lol.but i think i might get the new savage x ss kit.
