x ss will not shift
x ss will not shift
about a half gallon throught it high speed needle seems good i have not touched the low speed i like how its running but does not seem to shift.i did put big joes on not sure if that matters.
RE: x ss will not shift
im in sanabel for the winter im really from maine though.if i lean it much more it seems to make a popping sound at high end and if i richen it a little it sounds better.maybe time to adjust the low speed ?
have you tried adjusting the shift earlier i had this problem with my x and a adjusted it and it worked ......................scott
dont be scared, just remove the cover covering the gear box holes and turn the spur till u see the screw. turn it anti clockwise. bobs ure uncle.
