Dual disk brakes
Dual disk brakes
Which are the best dual disk brakes the hpi ones [link=http://www.hpieurope.com/piw.php?lang=en&partNo=87150]hpi[/link] or crazy nut ones [link=http://www.crazynutracing.com/product_info.php?cPath=67_51&products_id=245&osCsid=270479c3eba26c6b715b9f56bc24746a]crazy nut[/link] or any others?[sm=spinnyeyes.gif]
CO
RE: Dual disk brakes
I don't know about the crazy nut ones, but I have the HPI ones and I like them.
One bad thing is they can make the entire truck flip over fowords, unless you have tires with bad grip, like mashers, then It'll just skid to a stop
I have HPI dual disc (loosen the thumb wheel adjustment) and anti-lock setting on fast on my futabe radio.
Full control and stops fast without doing a brakie.
The Savage brakes can so bee improved for the cost HPI charges for them. Instead of using cheap-o gasket material for brake pads, they could go with a larger diameter disc and semi-metallic material for the pads. Too bad HPI and even aftermarket guys dont do that
i know a guy who uses cereal box cardboard on his buggy[X(] i will get the hpi ones soon then[sm=spinnyeyes.gif][sm=drowning.gif]
NY
I bought the HPI dual disc brakes but haven't installed them yet. My LHS have me a piece of fuel tubing and told me to replace the spring with it and the brakes work much, much better.
i did that only i used an old pice of lego peumatic tube as it is springy and hard works great brakes work great but still want more[>:]
I have them and I dont know why but I cant get as much braking power as you all can. I have had them for 1 gallon and have never done a brakie. I mean the braking is pretty strong like at full speed it stops in about 20 feet on full break but I cant get the tires to lock up or truck to flip over. IMO I think they are good brakes considering I got them for $12 and im on a budget
ORIGINAL: rcnitrohead
Everthing is as tight as can be without creating brake drag.
Cant really explain that well, a pic would show what i mean but the fuel tube works with the spring and pulls the brakes tighter.
My Feedback: (16)
CA
Hey, I have a quick question about the DD brakes; what is the diameter of the brake discs? If they are larger than 1.5", I will not be able to use them since they'll rub against the clutchbell. Thanks.
Kurt i already did that mod, as I said, everything is installed correctly and is screwed in as tight as can be without having brake drag. Pads are in good shape, i cleaned them 10 tanks ago. The servo is weak and doesnt have a large enough radius, i might upgrade to spectrum or futaba pk/pm later on wiht high torque servos later on Thats only if they open a track here for the summer.
