replaceing disk on savage
hi do you have to take the gearbox out to change the disk or is there a easier way of doing it thanks ........................scott
RE: replaceing disk on savage
The easiest way is to pull the rear clip off. 6 screws and a light pry on the chassis plates and it's off. Then you'll be able to get to the brake.
Back off the 4 screws holding your engine mount and then back off the two holding the bar inside of the bulkheads. Lightly pry apart your TVP's, slide out your engine plate and proceed to unscrew the brake assembly. That is the fastest way, lol I sound like an instruction manual dont I?
I was just messing with you. Take the rear-end off, so you can get to the breaks, it should not take more than 6 or 8 screws to slide the end off. Be sure to adjust them before you put the rear end back on.
OH
kill roy, that is the first half way useful information ive seen you give yet.. and as far as just messing with him, not necassary...
