Throttle/brake upgraded *finally*
RE: Throttle/brake upgraded *finally*
ORIGINAL: jtoothman25
What was used from the Servo to the linkage? I bought the ofna parts similar to yours, but what part attaches directly to the servo? I noticed the original has some sort of spring on it for the breaks?
Thank you a bunch. I bought the entire Ofna kit, that had the linkage and peices with it. It had two servo horns, well actually they were the X ones with four different sides. I just chopped off three of the four and drilled holes. Will take a picture when it's done. I'm going go order the one you suggest, it looks better (although mine looks okay for now).
Thanks for the idea, this will help out.
